[DesignModeler] cannot create inverse volume
Old   June 9, 2023, 13:39
Unhappy cannot create inverse volume
shafiq
royadfr is on a distinguished road
im trying to fill volume in my design in order to make a simulation in fluent to find flow velocity, but I'm having trouble to fill the void with volume in designmodeller. i don't know what else to do. I've closed all the opening in the design but still cant fill, please someone help. I've attached the problem, the message shown and my design
royadfr is offline   Reply With Quote
Old   June 13, 2023, 14:36
Erik
evcelica is on a distinguished road
You can try using the "enclosure" feature in Design modeler, which will make a box around your whole geometry. Then use some slices to slice off the box outside of your openings. The enclosure feature is much better than fill.
evcelica is offline   Reply With Quote
designmodeller, fluent 2022r1
[gmsh] How to create a 3D volume mesh using a existing surface mesh?! RobertHB Mesh Generation & Pre-Processing 0 July 20, 2017 09:12
How to use "translation" in solidBodyMotionFunction in OpenFOAM rupesh_w OpenFOAM Running, Solving & CFD 5 August 16, 2016 05:27
Stuck in a Rut- interDyMFoam! xoitx OpenFOAM Running, Solving & CFD 14 March 25, 2016 08:09
multiphase turbulance case floating error harsha_kulkarni OpenFOAM Running, Solving & CFD 3 February 18, 2016 06:06
[GAMBIT] how do i split volume or create volume surrounding pesar125 ANSYS Meshing & Geometry 1 December 17, 2013 02:07
