[Workbench] Extract a part of a 3D mesh in ANSYS workbench fluent
Old   May 17, 2023, 06:46
Default Extract a part of a 3D mesh in ANSYS workbench fluent
Mohamad Younes
Mohamad Younes is on a distinguished road
Hey,
I have done a 3D structure mesh for a Dual-Bell Nozzle in ANSYS Workbench fluent. I created the geometry in design modeler then in have done the mesh in the fluent workbench mesher. 5See the figures)
So as you see, i have done the mesh on a revolve of 360 degrees, but i want to use (extract) only 90 degress of this mesh. Because i want to do the simulation in OpenFoam and knowing that this is an axisymeric body i want to reduce the cost and time of my simulation by doing the siulation on only 90 degrees.
Any body know if i can Extract only 90 degrees of my mesh ?
Note: i want to extract a (.msh) file for use it in OpenFoam so i want to cut the mesh in the fluent mesher.
Thank you.
Mohamad Younes is offline   Reply With Quote
Error: WorkBench Error: Could not handle event: SolutionStatusUpdate Kieyo Fluent Multiphase 0 November 10, 2022 00:58
[ANSYS Meshing] How do I open a mesh made in Ansys Fluent 2020 R2 on Ansys Fluent 2019 R3? Ryan T ANSYS Meshing & Geometry 3 November 3, 2021 16:44
Trouble modelling a 2D gear pump simulation using dynamic mesh in Ansys Fluent 19 vivjk94 Main CFD Forum 0 September 20, 2021 01:25
Transfer of mesh from Meshing to Fluent destroys the mesh balrog_f FLUENT 9 July 28, 2018 11:02
[ANSYS Meshing] Difficulty in mesh upload to ansys fluent Ayo_gboyega ANSYS Meshing & Geometry 1 June 17, 2018 04:02
