May 2, 2023, 05:31 |
Trapezoidal channel meshing
josé francisco
Hello!
I'm trying to achieve a mesh like the one attached. I've tried using face meshing + edge sizing while sweeping the mesh throughout the channel, but the results are not even close, with high skewness. I'm importing the geometry from SolidWorks. Could someone help me with the best way to achieve a mesh similar to this one? I'm new to meshing processes. |
May 9, 2023, 10:06 |
Chrowale
Rep Power: 5 |
Looks like the mesh is generated from a structured mesh or they intentionally splitting the surfaces in the geometry to get the blocking look. It also could probably be a multizone mesh (I've never used it, correct me if I'm wrong).
meshing, skewness, trapezoidal channel |
LES Setup of a cyclic channel flow for compressible solver | Phil910 | OpenFOAM Running, Solving & CFD | 3 | November 14, 2024 08:42 |
[ICEM] Flow channel meshing problems | StefanG | ANSYS Meshing & Geometry | 19 | May 15, 2012 07:44 |
[ANSYS Meshing] Meshing a Periodic channel with high curvature 2D airfoil | ergometer | ANSYS Meshing & Geometry | 4 | February 22, 2012 10:13 |
[ANSYS Meshing] Micro channel waterblock meshing. | codenamew | ANSYS Meshing & Geometry | 0 | January 2, 2012 10:55 |
tetrahedral meshing in square channel | Aashutosh Magdum | FLUENT | 4 | May 28, 2005 21:27 |
