[Other] Spaceclaim scripting, get centroid of surface body
Old   April 21, 2023, 04:15
Default Spaceclaim scripting, get centroid of surface body
DEd
Daniel Edebro
DEd is on a distinguished road
Hi, I would like to create a script in spaceclaim that automatically creates a point at the centroid (center of an area) of a surface body (the surfaces are always planar in my use case if that helps).
1. Select surface
2. Run script and get a point at the centroid of that face.
What I have tried:
I have found the MeasureHelper class that has a method called MeasureHelper.GetCentroid that sound suitable. This method expects an object that implements ISelection. How do do I get an object that implements this?
DEd is offline   Reply With Quote
Old   April 23, 2023, 06:27
Lightbulb
DEd
Daniel Edebro
Just as an update. I found the solution to this problem myself.
This script works like this:
1. Select the faces you want to create the centroid for (note: don't select the surface bodies)
2. Run this script:
# Python Script, API Version = V21
selected_items = Selection.GetActive().Items
for selected_item in selected_items:
    if not isinstance(selected_item, DesignFace):
        continue
    sel_i = Selection.Create(selected_item)
    pt=MeasureHelper.GetCentroid(sel_i)
    new_pt=SketchPoint.Create(pt)
scripting, spaceclaim
[Gmsh] gmshToFoam generates patches with 0 faces and 0 points Simurgh OpenFOAM Meshing & Mesh Conversion 4 August 25, 2023 08:58
OpenFOAM error Vinay Kumar V Main CFD Forum 0 February 20, 2020 10:17
[DesignModeler] Merge Surface Body and Solid Body prikeyma ANSYS Meshing & Geometry 5 April 16, 2015 08:01
[DesignModeler] Boolean Subtract of a body and a surface KrishnaSandeep ANSYS Meshing & Geometry 2 April 1, 2015 16:55
[snappyHexMesh] Layers don't fully surround surface EVBUCF OpenFOAM Meshing & Mesh Conversion 14 August 20, 2012 05:31
