[ANSYS Meshing] Body of influence and body named selections |
Iason
Rep Power: 3 ![]() |
Hello everyone,
I'm kind of a new user of ANSYS products, currently working on a conjugate heat transfer problem (battery cooling). I have created my battery domain surrounded by a fluid enclosure in Design Modeler and generated a "CutCell" mesh using the "Assembly Meshing". Then, wishing to locally refine my mesh, I use the "Body Sizing" option and further select "Body of Influence" as its type. However, a problem arises; after I create the "Body of Influence", I cannot create a "Body Named Selection" for the "Body of Influence". These two, namely the "Body of Influence" and the "Body Named Selection" seem mutually exclusive. To illustrate further, the "Scoped" body is the enclosure, the "Body of Influence" is the battery, and what I would also like to add (but cannot) is a "Body Named Selection" for the battery. I'm using ANSYS 2022R1 on a Linux PC. Has anyone experienced something similar and is willing to share it? Thank you very much in advance. |
ansys mesh, body named selection, body of influence |
[ANSYS Meshing] body of influence vs. contact region | Diger | ANSYS Meshing & Geometry | 5 | October 10, 2018 07:41 |
[ANSYS Meshing] Body of influence substracts from part in Ansys Meshing | wimblo | ANSYS Meshing & Geometry | 0 | May 2, 2018 09:00 |
[ANSYS Meshing] Creating local sizings within a body of influence. | Euan001 | ANSYS Meshing & Geometry | 1 | May 6, 2016 04:19 |
[ANSYS Meshing] body of influence for mesh method | Ema40 | ANSYS Meshing & Geometry | 0 | April 21, 2016 07:22 |
[ANSYS Meshing] Body of Influence | MuhammadK | ANSYS Meshing & Geometry | 3 | January 8, 2016 01:27 |
