[ANSYS Meshing] Ht33 Shell and Tube Heat Exchanger
Old   April 2, 2023, 22:05
Default Ht33 Shell and Tube Heat Exchanger
Mark
LumberSnack is on a distinguished road
I am attempting at model and simulate the Armfield HT33 shell and tube heat exchanger. I have modelled the Hot & Cold fluid domains as well as the 7x tubes that contain the hot fluid. I want to simulate conjugate heat transfer and I am having trouble creating a conformal mesh that is <512,000 elements + nodes. My goal is to determine the overall heat transfer coefficient for this model.
I seem to get the tubes and hot fluid domain conformal however, I can't seem the get the cold fluid domain conformal with the tube wall.
Any advice? (Design Modler & Mesh images below)
Thanks for your time.
LumberSnack is offline   Reply With Quote
Old   April 20, 2023, 13:45
Erik
evcelica is on a distinguished road
1.) Use symmetry to cut the size of your model in half since you are limited by node count.
2.) In Design Modeler, select al bodies, right click, and "create part". This will give you a conformal mesh across bodies.
evcelica is offline   Reply With Quote
ansys, ansys meshing, cfd, heat exchanger model
Multiphase Flow Problem in Shell and Tube Heat Exchanger Arhaam_Mubarak Fluent Multiphase 1 April 29, 2022 06:48
What is the boundary condition for shell and tube heat exchanger ? miftahazhar FLUENT 0 July 14, 2019 02:52
Defining Boundary Condition of Simulation of Shell and Tube Heat Exchanger ? miftahazhar FLUENT 0 June 26, 2019 11:34
Regarding change of tube material of shell and tube heat exchanger kkj1234 FLUENT 0 October 16, 2016 23:39
How to carry out 3D shell and Tube Heat Exchanger analysis in fluent medogalal FLUENT 3 December 30, 2015 05:28
