[Workbench] 2-Way FSI Poor Intersection
Old   December 7, 2022, 22:02
Question 2-Way FSI Poor Intersection
Alexander Eichenbrücke
Zandepc is on a distinguished road
Hello all,
While trying to simulate a ramjet motor in Fluent-Mechanical, the following error appeared in System Coupling:
"(DP 0) Poor intersection was identified between the source and target. This error check is triggered when the mapping fraction for both source and target are below the threshold set by MappingControl/PoorIntersectionThreshold (currently 0.5). Please review the mapping details written to the folder 'Results_PoorIntersection' in Ensight for potential setup issues. It may also be helpful to (a) increase the Absolute or Relative Gap Tolerance (if the interfaces are separated) or (b) change Face Alignment (if the interface mesh normals are inward-directed or if there are shell elements). You can deactivate this check with MappingControl/StopIfPoorIntersection. Please do not save the project if you would like to recover to the last saved state."
After further investigation, I saw that Mapped Area [%] for both source and target are at 0, even after defining the Fluid-Solid Interface in Mechanical and Dynamic Mesh in Fluent and trying to build a conformal mesh.
Couldn't attach my project since the .zip was too large. I can send it through e-mail, if anyone wants.
Any help would be appreciated. Thanks
Zandepc is offline   Reply With Quote
Old   December 29, 2022, 03:12
hayder kareem
hayder37 is on a distinguished road
I have the same problem did you get the solution.
hayder37 is offline   Reply With Quote
Old   December 29, 2022, 08:00
Not yet, unfortunately.
2 way fsi, coupling, fluent, fsi, mechanical
[FSI] Sudden divergence of elastic pipe FSI MFWilliams OpenFOAM CC Toolkits for Fluid-Structure Interaction 1 June 16, 2022 12:35
[solids4Foam] FSI case does not converge, foam extend 4.0 MFWilliams OpenFOAM CC Toolkits for Fluid-Structure Interaction 12 May 13, 2022 09:35
Strongly FSI scheme in OF WUYing OpenFOAM Running, Solving & CFD 0 January 26, 2022 00:29
BCs in an FSI simulation of a flexble pipe vivekcfd OpenFOAM 10 January 8, 2010 05:14
how to extend FSI 2D codes to 3D, need advises abouziar Main CFD Forum 1 May 30, 2008 05:08
