[Workbench] workbench design and mesh
Old   December 6, 2022, 14:25
Post workbench design and mesh
Abdelhamid
meedomagdy is on a distinguished road
hello, everyone.
I just started using CFD Ansys fluent for my master and I would like to ask some questions about the problems I'm currently facing:
1- I need to design a hollow step ladder that the audience will be sitting on but I can't think of a way to create it and also make holes at the top through which air will flow ( air enters inside the hollow ladder and exit from holes at the top which is below the seat of the audience)
2- for that kind of hollow body which type of mesh should be better Hexa or tetra
3- is share topology necessary without it I always have overlapped bodies but if I made share topology the bodies won't be sweepable bodies and cant create hex even if I used multizone
4- also the holes at the top of the ladder can they be created as a surface and choose type as fluid or it has to be made through cut material
meedomagdy is offline   Reply With Quote
design, theater
[ICEM] Bad Quality Hybrid Mesh External Flow tim13 ANSYS Meshing & Geometry 0 March 8, 2020 03:22
[Workbench] Exporting mesh for every design point Janusz13 ANSYS Meshing & Geometry 0 December 18, 2018 19:17
Parametric Mesh with ICEM and Workbench fails to update fabian.schicker ANSYS 0 May 9, 2017 09:20
[Workbench] Standard workbench mesh convergent issues wind_tunnel_contraction ANSYS Meshing & Geometry 0 April 29, 2016 07:34
[ANSYS Meshing] Structured hexahedral mesh in workbench Chander ANSYS Meshing & Geometry 3 November 2, 2011 04:32
