[ANSYS Meshing] Inflation on 2 perpendicular edges to size cells
Old   November 30, 2022, 13:51
Default Inflation on 2 perpendicular edges to size cells
Haaziq
Haaziq is on a distinguished road
Hi, I am trying to add inflation to 2 perpendicular so that cell width increases in the x direction and cell height increases in the y direction as illustrated by this sketch.
Unfortunately, the result I currently have is this:
There are skewed elements close to the edges since the application is thinking of both inflation features as 1 inflation layer around a corner. How do you get an inflation in x to act independently from another inflation in y in order to size cells?
How do I achieve this using inflation only? I want to resolve the shear layers out of a nozzle which is why I want to specify a minimum cell height and width. I know I can approximate the effect using edge sizing and bias but I want to know how to this using inflation.
Thank you.
Haaziq is offline   Reply With Quote
inflation, shear layer, sizing
Averaging over iterations for steady-state simulation CFD student Fluent UDF and Scheme Programming 8 September 22, 2022 04:39
SimpleFoam & Theater jipai OpenFOAM Running, Solving & CFD 3 June 18, 2019 11:11
cellZone not taking all the cells inside rahulksoni OpenFOAM 0 January 16, 2019 02:16
[snappyHexMesh] crash sHM H25E OpenFOAM Meshing & Mesh Conversion 11 November 10, 2014 12:27
killed "snappyHexMesh" parkh32 OpenFOAM Pre-Processing 2 April 8, 2012 18:12
