Sai Guruprasad Jakkala
Rep Power: 9 ![]() |
I am trying to mesh many small fins on a plate. I tried creating prism layers using the Prism layer, but ICEM was not able to generate the Prisms.
I extruded the fin faces along the surface normal and was able to generate the prisms, but I am not sure how I can merge it with the surface above and below the fins. Attached picture showing the prism layer by extrusion (green) and the surface mesh (blue). How can I move the surface mesh around the prism layers generated by extrusion? merge_mesh.png |
extrusion, icem 3d, prism layer, tetra and prisms |
[mesh manipulation] Merging meshes for chtMultiRegionFoam | Hr_kules | OpenFOAM Meshing & Mesh Conversion | 3 | July 30, 2022 13:15 |
[mesh manipulation] Merging meshes for chtMultiRegionFoam | Hr_kules | OpenFOAM Meshing & Mesh Conversion | 0 | May 12, 2022 08:00 |
[ICEM] Merging Hexa Meshes in ICEM | screech1987 | ANSYS Meshing & Geometry | 11 | March 13, 2014 11:45 |
merging meshes | amirr | OpenFOAM Running, Solving & CFD | 2 | July 23, 2012 09:30 |
Merging Meshes | Matteo Giacobello. | FLUENT | 1 | February 16, 2000 09:22 |
