[ANSYS Meshing] Volume meshing supposedly not successful due to 'unresolved gaps' error?
Old   October 3, 2022, 06:54
Unhappy Volume meshing supposedly not successful due to 'unresolved gaps' error?
MEGAMAN is on a distinguished road
Hello all,
I am having a rather strange error when trying to generate the volume mesh for my fluid domain in Fluent Meshing watertight workflow.
I have already done a baseline simulation with an initial domain size without issues, but now am doing the same steps for a smaller domain. So all I changed in SpaceClaim is the enclosure size and then reselected my inlet, outlet, symmetry and wall named selections. I then used the same mesh settings and yet I am getting this error when trying to generate the volume mesh:
The tgrid process could not be started. Error: Auto mesh failed.Error Object: #f
Error: Volume meshing was not successful, likely due to unresolved gaps. Edit the Create Volume Task and in Advanced Options, set Check Self Proximity to 'yes' before re-execution.Error Object: #f
Error: state/object/execute-command:Exception encountered in S_ExecuteTaskError Object: ()
How can the same domain that worked fine before, now have unresolved gaps when all I changed was the size of the enclosure?
Any help to resolve this issue would be much appreciated, thanks!
MEGAMAN is offline   Reply With Quote
Old   October 10, 2022, 11:18
kjetil is on a distinguished road
Did you check the Self proximity, as it suggests?
kjetil is offline   Reply With Quote
enclosure, error #f, fluent meshing watertight, spaceclaim, unresolved gaps
error compiling modified applications yvyan OpenFOAM Programming & Development 21 March 1, 2016 05:53
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 07:42
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 18:38
