[ICEM] How to deal with negative quality mesh elements in ICEM CFD mesh?
Old   September 19, 2022, 07:04
Default How to deal with negative quality mesh elements in ICEM CFD mesh?
Murali Krishnamraju
murali666 is on a distinguished road
I am trying to develop a Hexa mesh in a flow domain with a cylinder in a scour hole. The flow domain is shown below.
The bottom surface and the cylinder surface are treated as walls, and hence the inflation layers are provided around them.
The developed mesh contains some negative quality elements at the intersection of the cylinder with the bottom surface.
How can I remove those cells from the mesh?
I tried pre-mesh smoothing but was unable to remove them.
Please find the figures below
murali666 is offline   Reply With Quote
Old   September 20, 2022, 05:10
Gert-Jan
Gert-Jan will become famous soon enough
Difficult to say. In my experience, the best results are obtained if the points and curves of a geometry match with the vertices and edges of the blocking structure. In your second figure I see 2 curves on the cilinder. These are not aligned with the 4 edges on the cilinder of the blocking structure. Therefore, create 2 more curves (and points) and make sure these are aligned with the edges by rotating all curves and points by 45°.
Also, show a picture of the pre mesh on the surfaces. These might tell a lot on wrong projection. Regarding this projection, first create a pre mesh without projection. If this works okay, then mesh with edge projection, and then withh surface projection. In this way it might become easier to see where the problems occur.
Gert-Jan is offline   Reply With Quote
Old   September 27, 2022, 03:46
Murali Krishnamraju
Thank you for the response,
The cylinder has four curves and each curve is associated with an edge around the cylinder.
Coming to the premesh, I am giving a number of nodes to each edge and then generating the mesh and then converting it into an unstructured mesh.
I am exporting that mesh to fluent to run the simulation.
Is there any other way to generate the hexa pre mesh in ICEM CFD?
Old   September 27, 2022, 06:35
Gert-Jan
If I zoom into your picture, I see edges (black) from your blocking structure and curves (blue) from your geometry. They are 45° rotated from each other so they are not aligned. This might lead to problems.
I suggest to delete the curves and points on the cilinder and have the vertices associate on the curve the top of the cilinder and associate the edges with the outer surface.
If this does not work, create new curves and points where you want the edges and vertices to be.
hexa blocking, hexa meshing, hexaedral meshes, icem 19.2, icem cfd
[ICEM] Improving Mesh Quality in ICEM CFD illuminated ANSYS Meshing & Geometry 6 January 4, 2021 21:13
[ICEM] Heart modeling - ICEM Hexa Mesh quality improvement heart_modeller ANSYS Meshing & Geometry 1 April 8, 2016 09:16
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 14:06
