[Other] Change minimum size in sketch SpaceClaim
Old   September 15, 2022, 11:00
Default Change minimum size in sketch SpaceClaim
Rodrigo Villarreal
rodrigovime is on a distinguished road
Hello everybody,
I'm making a very simple wedge like geometry in SpaceClaim but when I try to do a very short line (about 0.01 mm) it gives me the warning:
"One or more of the created curves was below the minimum size for use with sketch constraints"
And doesn't draw the line. Does anyone know how to change that minimum size for sketching, or if it is even possible to draw lines that short?
Thank you
rodrigovime is offline   Reply With Quote
Old   September 16, 2022, 08:33
Gert-Jan
Gert-Jan will become famous soon enough
A work around is to create a geometry 1000 times larger, mesh it and then scale it back in the solver. At least in CFX and Fluent this is possible.
Gert-Jan is offline   Reply With Quote
Old   September 16, 2022, 22:52
Rodrigo Villarreal
Thanks, I'll try it.
ansys, sketch in ansys, spaceclaim
[Other] dynamicTopoFVMesh and pointDisplacement RandomUser OpenFOAM Meshing & Mesh Conversion 6 April 26, 2018 08:30
minimum grid size in gas flow simulation in cylinder YHY CONVERGE 1 October 30, 2017 07:49
How to use "translation" in solidBodyMotionFunction in OpenFOAM rupesh_w OpenFOAM Running, Solving & CFD 5 August 16, 2016 05:27
Minimum possible element size Tscar Main CFD Forum 3 February 12, 2016 14:50
minimum mesh size for CFX julien CFX 1 January 12, 2006 07:37
