September 9, 2022, 06:12 |
My inquiry about Boolean.
Mojtaba
While I was analyzing the fluid flow for a geometry, I encountered a problem. The problem that I faced is that, when adding Boolean (subtract) in DesignModeller - in order to subtract a geometry (solid) from air (fluid), the Ansys then says that operation would result in non-manifold bodies. In some occasions, it just says, Boolean operation failed. I actually tried many ways to fix the issue however I still couldn't (e.g. I tried the FILL method, I changed the tolerance, I simplified the geometry, etc). I even worked with my geometry in Solidworks (the geometry is prepared via Solidworks), this also didn't help to fix the issue.
Can I therefore please inquire how I can perform the Boolean operation (subtract) for my geometry? Thank you so much. |
ansys, boolean operation error. |
[DesignModeler] Problem with Boolean Subtract | collie | ANSYS Meshing & Geometry | 0 | December 10, 2018 06:42 |
Fluent does not launch from workbench | NickyNac | FLUENT | 8 | April 13, 2018 10:42 |
Error when loading the solution | pcn90 | FLUENT | 0 | June 8, 2017 07:37 |
[ansys fluent] problems of running ANSYS 12.1 fluent module | mkwang2006 | FLUENT | 3 | September 30, 2013 11:59 |
Info message -> Fluent does not start | Jenson | FLUENT | 0 | December 22, 2011 18:21 |
