[ANSYS Meshing] Capping Fluid Regions - Problem at defining Inlet & Outlet |
September 8, 2022, 05:49 |
it's the first time i'm using Fluent Meshing and got following problem. I defined the surfaces of the inlet and outlet at spaceclaim as named selection. You can see it at the attachment. At Fluent Meshing at the step 'Enclose Fluid Regions' i use the defined label 'named selections' from spaceclaim but get the following error: ---- Warning--- Intesecting caps were detected and deleted. Error: Created caps were self-intersections with the mesh and removed Error Object: #f I also try it by choosing two zones and as cap type Annular (2 surface) but get the same error. Hope someone can help me as fast as possible. |
capping, fluent meshing, meshing |
[OLAFLOW] The OLAFLOW Thread | Phicau | OpenFOAM Community Contributions | 459 | September 12, 2024 12:47 |
dsmcFoam setup | hherbol | OpenFOAM Pre-Processing | 1 | November 19, 2021 02:52 |
SU2-7.0.1 on ubuntu 18.04 | hyunko | SU2 Installation | 7 | March 16, 2020 05:37 |
natural convection in square cavity having inlet and outlet | sujeet | OpenFOAM Running, Solving & CFD | 1 | November 2, 2019 03:17 |
Defining contact regions in FSI problem.!!! | sreemvlk | ANSYS | 0 | June 12, 2014 01:33 |
