[ANSYS Meshing] Vertical Axis Savonius Turbine |
August 20, 2022, 11:31 |
Shehabeldeen
Rep Power: 4 |
Currently I'm making mesh on the following
I drew 3 bodies inner domain outer domain Turbine And made two booleans Now I only have the outer and inner domain as two bodies now I want to make inflation around the blades of turbine any help ??? |
Vertical Axis Savonius Turbine | shehabeldeen | FLUENT | 0 | August 8, 2022 04:24 |
Fluent setup for vertical axis wind turbine | Richard23 | FLUENT | 0 | November 14, 2020 22:56 |
Need to output surface pressure on blades in a vertical axis wind turbine | kmallick | OpenFOAM Post-Processing | 1 | October 22, 2018 00:08 |
Vertical Axis Wind Turbine (VAWT) simulation | Jorge22 | CFX | 5 | November 18, 2017 06:18 |
Vertical Axis Wind Turbine | atorninc | Main CFD Forum | 3 | March 6, 2013 05:38 |
