[ANSYS Meshing] Reduce mesh elements and nodes |
July 30, 2022, 13:24 |
Gabriel
Rep Power: 5 |
Hi, i have ansys student version and i want to simulate compression strength of cardboard pieces (link), im using explicit dynamics (or should i use transient structural?), when i use element size 0,001 [m] meshing works, but element and node count exceed 128k limit (~189k), how i reduce elements and nodes without having the mesh failing?
scdoc file: https://www.dropbox.com/s/1sjnr8jr12...ong.scdoc?dl=0 |
August 2, 2022, 10:55 |
Gabriel
Rep Power: 5 |
so i used a shell mesh, this solved the problem
FLUENT adding mesh nodes problem when importing 3D mesh from ICEM | guxin7005 | FLUENT | 2 | June 27, 2016 22:41 |
Ansys SIG$ILL error | loth | ANSYS | 3 | December 24, 2015 06:31 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 07:42 |
2d irregular grid | Remy | Main CFD Forum | 1 | December 22, 2008 05:49 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
