[ANSYS Meshing] O-grid mesh on cylinder with 90 degree angle not pretty
Old   July 12, 2022, 07:57
Default O-grid mesh on cylinder with 90 degree angle not pretty
Benjamin
Benzouz is on a distinguished road
Hello all,
I've been following a tutorial on how to create an O-grid mesh on a cylinder geometry (https://youtu.be/8_osCXZjv_g) and it worked well. However, when applying this same technique on a cylinder with a 90 degree bend I don't get something as nice as for the straight cylinder.
Here's what I get for the cylinder with the bend:
And here is what I get for the straight cylinder:
The dimensions of the circle at the base of each cylinder are different, but I have kept the ratios between the size of the square and the size of the circle similar.
Any ideas on why this happens and how to solve it?
Thanks!
Benzouz is offline   Reply With Quote
Old   July 12, 2022, 08:37
Benjamin
Actually I managed to solve this by setting up an edge sizing on both the square in the middle and on the edges on the sides of the pipe. I had tried this before posting initially but I guess I hadn't set up the right parameters in the number of divisions.
Old   July 13, 2022, 07:13
Benjamin
By the way as I mentioned in the first I had originally kept the same ratio of the square to the circle diameter as in the tutorial, but it seems if I take one slightly different it doesn't work as well:
So once again I'm stuck. Tried playing with different edge sizing but with no luck this time
Old   July 18, 2022, 09:28
siw
Stuart
siw will become famous soon enough
Did you check the lower two edge biasing directions?
siw is offline   Reply With Quote
[snappyHexMesh] non uniform mesh near the stl object vava10 OpenFOAM Meshing & Mesh Conversion 0 January 31, 2021 15:41
Forces Acting on a Rotating Cylinder (Moving Mesh) dreamchaser CFX 5 April 25, 2015 07:01
Mesh Gambit (cylinder with block) with multiblock grid pedrin84 ANSYS Meshing & Geometry 2 July 24, 2011 13:03
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 06:59
