[Workbench] Create interface for VAWT in Watertight Geometry Workflow (Fluent Meshing)
Old   June 26, 2022, 08:02
Default Create interface for VAWT in Watertight Geometry Workflow (Fluent Meshing)
Hihihaha
minhkuoa7 is on a distinguished road
Currently, I am trying to mesh a vertical axis wind turbine, the requirement is that there will be two interface surface layers overlapping to perform the sliding mesh simulation in Fluent. However, I named these two overlapping faces in the Spaceclaim, after meshing with Fluent Meshing, the software asks to share the topology and automatically removes one overlapping plane.
Can you give me some helpful advice on the problem I'm having? Thank you very much!
minhkuoa7 is offline   Reply With Quote
interface domains, meshing 3d, turbine mesh
fluent Note: zone-surface: cannot create surface from sliding interface zone sachinip FLUENT 4 November 12, 2014 11:00
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
[ICEM] Interface meshing at dual zone geometry hamedi.m.reza ANSYS Meshing & Geometry 12 May 6, 2012 01:38
Actuator disk model audrich FLUENT 0 September 21, 2009 08:06
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 02:07
