[ANSYS Meshing] How can fix the warp problem? |
jefferson
Rep Power: 4 ![]() |
Hi everyone, I'm meshin with 'with Fluent Meshing' when I finish the mesh and check, appear the next message: 'Warning: 14 faces have warp greater than or equal to 0.5.' How can I fix this problem.
Also mesh quality is good, Orthogonal Quality, most cells are close to 1 (0.74); Skewness, most cells are close to 0; Aspect Ratio, most cells are less than 10. Geometry is in 3D. Type of mesh: Poly-hexcore Thank you for any help that will be provided. |
ansys, mesh 3d, poly hex-core mesh |
area does not match neighbour by ... % -- possible face ordering problem | St.Pacholak | OpenFOAM | 11 | September 4, 2024 04:28 |
Convergence Problem in Multiphase problem (three phases) | m.uzair | FLUENT | 0 | August 2, 2018 08:23 |
Large problem partitioner | tzy | CFX | 3 | February 7, 2018 17:11 |
HOWTO fix mpirun problem | JunaidAhmad | OpenFOAM | 3 | April 29, 2011 13:21 |
How to fix this problem? | mehul | FLUENT | 0 | February 6, 2007 03:10 |
