June 3, 2022, 12:11 |
Importing CGNS mesh file
Rajat
Hi
I have CGNS mesh files which I want to import into a meshing software and then make the mesh finer but I tried to do it in ICEM CFD and It won't let me modify the mesh. ICEM only let me change the mesh to geometry and then perform meshing from scratch on the geometry which was not helpful at all. I have tried using Fluent meshing but it doesnt let me import the CGNS files but I imported the ICEM mesh output files in Fluent meshing and then the meshing is put into unreferenced section. Can someone please help me with it? Thanks |
#ansys #mesh#icem#fluent |
[swak4Foam] Installation Problem with OF 6 version | Aurel | OpenFOAM Community Contributions | 14 | November 18, 2020 16:18 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
