[ANSYS Meshing] Poor element quality at edge of a thin plate in an airstream
Old   June 2, 2022, 17:39
Default Poor element quality at edge of a thin plate in an airstream
garrett
gcapp5893 is on a distinguished road
Is there a preferred method of fixing highly skewed/poor quality elements at the edge of a thin (2 mm) flat plate in a flow field?
Thanks
gcapp5893 is offline   Reply With Quote
Old   June 3, 2022, 04:57
Gert-Jan
Gert-Jan will become famous soon enough
need more info like pictures, inflation, etc.
Gert-Jan is offline   Reply With Quote
Old   June 3, 2022, 05:19
Chrowale
mluckyw is on a distinguished road
If Structured, You could try using O-grid in the blocking.
If Unstructured, You could reduce the minimum size or the maximum size at the edge.
mluckyw is offline   Reply With Quote
elements, mesh, quality, skewed, thin
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 02:07
[Commercial meshers] Star mesh import problem chris1980 OpenFOAM Meshing & Mesh Conversion 20 May 8, 2006 02:07
Best leading edge for a Flat plate Rodge FLUENT 0 April 29, 2003 20:29
Parallel Plate Rheometer vs Cone & Plate beginner Main CFD Forum 0 March 19, 2003 12:49
