[ICEM] Meshing parameter not showing correct value |
May 21, 2022, 08:55 |
Md. Mesbahose Salekeen
Rep Power: 8 |
I am trying to mesh Airfoil NACA-66(3)-018 with ICEM CFD ANSYS R2 2020
How do i fix this? |
May 27, 2022, 03:17 |
Alain Islas
Rep Power: 6 |
When defining the number of nodes on either edge, please be sure to check box "copy to parallel edges"
May 31, 2022, 02:15 |
Chrowale
Rep Power: 4 |
This has to do with the differing mesh law in each edge. Usually if generated using ICEM global setting, sometimes it has a mind of its own . I prefer to do it manually by parallel selections.
Regards Lucky |
icem 2d blocking, mesh 2d |
[Gmsh] gmshToFoam generates patches with 0 faces and 0 points | Simurgh | OpenFOAM Meshing & Mesh Conversion | 4 | August 25, 2023 07:58 |
[ANSYS Meshing] Help about meshing well | berkmm | ANSYS Meshing & Geometry | 1 | May 11, 2020 15:32 |
meshing small gaps: what parameter do I have to keep that holes clear? | pablo_fil | STAR-CCM+ | 1 | November 16, 2014 06:02 |
Meshing software comparison | Wikie | Mesh Generation & Pre-Processing | 5 | September 29, 2014 06:09 |
Volume Meshing & Face Meshing? singularity of grid | ken | FLUENT | 0 | September 4, 2003 11:08 |
