[ANSYS Meshing] Periodic boundary condition failure |
May 5, 2022, 14:21 |
Sakun
Rep Power: 6 |
I created my naca65-009 blade using ICEM and top , bottom have a distance of 134. after scaling down to mm in the fluent , i tried to set up periodic conditions to the top and bottom but none of the methods worked. tried both manual and automatic detection. even if i gave 0.134 to the manual detection , it did not captured. can someone help me on this |
May 6, 2022, 03:46 |
Gert-Jan
Rep Power: 27 |
Don't use fluent for this. CFX is made for rotating equipment.
May 6, 2022, 06:00 |
Sakun
Rep Power: 6 |
so does it mean, it is impossible in fluent ?
the thing is i have never used cfx |
May 6, 2022, 12:24 |
#4 | |
Void_CFD-user
Rep Power: 4 |
Fluent also has a Turbo-workflow specially designed for turbo application. It's a very old idea that CFX is for turbo and fluent isn't, usually said by people who are not up to date with CFD development, things have changed substantially. Also, try using Turbo grid or Fluent Meshing for mesh generation. These are the new and updated packages, ICEM is not really being used much in the industry. |
May 6, 2022, 12:25 |
#5 | |
Void_CFD-user
Rep Power: 4 |
May 11, 2022, 12:20 |
Gert-Jan
Rep Power: 27 |
I think Fluent is horrible when it comes to transient analysis. It is not even possible to only save pressure and velocities field every time step. The Data File Quantities list only allows me to select all variables. Very inefficient and it is eating my hard disk.
CFX is forgiven to bad elements. Fluent crashes immedietely. |
May 11, 2022, 13:20 |
#7 | |
Void_CFD-user
Rep Power: 4 |
As far as issues with accuracy and convergence are concerned, there isn't much difference between CFX and Fluent(although they are essentially different solvers), both are excellent, depends on mesh quality. Fluent has it's own mesher that does poly and poly-hexcore meshing using parallel computing, so less element overall and much faster mesh time. Again, both are owned by the same company, they are equally good, although they are focusing more on developing Fluent as it is their main product. |
May 9, 2023, 21:28 |
Florence Pugh
One potential solution to fix this issue is to ensure that your mesh is properly aligned and centered around the blade. If your mesh is not properly aligned, the periodic boundary condition setup may fail. contexto
fluent, icem, icem 2d blocking, periodic bc, periodic boundary fluent |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Turbomachinery Mass imbalance | sheaker | CFX | 12 | September 5, 2019 08:09 |
Problem in setting Boundary Condition | Madhatter92 | CFX | 12 | January 12, 2016 04:39 |
Unsteady Periodic Boundary Condition | EMolina | SU2 | 0 | July 24, 2014 16:16 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
