[ANSYS Meshing] First layer cells are not attaching to the wall
Old   April 23, 2022, 14:27
Default First layer cells are not attaching to the wall
Sakun
Sakun is on a distinguished road
I was meshing a compressor blade using o-grid tool and recenlty found out that first layer cells are not attaching to the blade as i shown in the attachments.
any suggestions would be highly appriciating
Sakun is offline   Reply With Quote
Old   April 23, 2022, 15:14
Kira
aero_head is on a distinguished road
Did you associate the lines correctly? This looks normal to me, it’s just the mesh preview. You can mesh it and see the actual results by using a cut plane. Let us see the cut plane view.
aero_head is offline   Reply With Quote
Old   April 23, 2022, 16:05
Sakun
sorry, i dont know how to use "cut plane" option as shown in the pic, this is how far i went
Old   April 23, 2022, 16:24
Kira
Sorry, I meant a scan plane, the option just under the cut plane. My bad, I mix those up all the time. And also please zoom in on the feature
Old   April 23, 2022, 17:14
Sakun
that is alright , i really appriciate your help
i tried to work with scan planes but could not get anything
Old   April 23, 2022, 22:28
Kira
Okay, I had the chance to open ICEM to give more detailed instructions.
I have attached a photo. You will see the features you need in that photo.
First, go to Pre-Mesh -> Right click -> select scan planes.
Next, when another window appears for the scan planes, you have to click one of the check boxes (under the heading 'On') to enable the mesh to be visible on a plane. Enable one of the boxes that will give an XY plane, then press the up and down arrows on the right or left of that box on the plane you just made visible to make it as vertical as you can. Please capture and upload a photo that is zoomed in on the surface of your compressor blade with the mesh showing in this way.
You nearly got it with the photo in your last message, but I want to see the mesh itself, not just the blocks. You need to just enable the mesh/pre-mesh. You can also zoom in a bit more on the surface of the compressor blade.
Old   April 24, 2022, 17:47
Gert-Jan
Gert-Jan will become famous soon enough
Originally Posted by Sakun View Post
You have set no bunching on the edge parallel to the blade. So your whole block consist of only 1 element. For that reason it is not strange that it does not attach to the blade.
If you would set 10 elements (or even more) on the edge, then the first layer would follow the blade much better.
Gert-Jan is offline   Reply With Quote
icem 2d, icem 2d blocking
addLayers with snappyHexMesh at small Cells ani6486 OpenFOAM Pre-Processing 0 December 8, 2020 05:14
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 01:04
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
physical boundary error!! kris Siemens 2 August 3, 2005 01:32
