April 11, 2022, 07:33 |
o grid mesh distorting tip geometry
Rep Power: 5 |
Hello
I am trying to generate by an o-grid on the tip of a wing. But, in contrast to the mesh on the wing body, the mesh on the wing tip is distorting the geometry. link to the file: https://drive.google.com/file/d/1TZy...ew?usp=sharing Captura de Tela (89).jpg Captura de Tela (90).jpg Captura de Tela (91).jpg |
April 13, 2022, 16:31 |
Kira
Rep Power: 8 |
Hi there,
What is your mesh quality, specifically at the wing tip? I’m guessing there may be an issue with the elements there. |
icem cfd, wing tip |
foam-extend-4.1 release | hjasak | OpenFOAM Announcements from Other Sources | 19 | July 16, 2021 05:02 |
[snappyHexMesh] non uniform mesh near the stl object | vava10 | OpenFOAM Meshing & Mesh Conversion | 0 | January 31, 2021 14:41 |
FFD shape deformation for 3D wing not changing the mesh | lwc24 | SU2 Shape Design | 5 | August 1, 2019 15:17 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 10:09 |
