[Other] radial diffuser geometry generation problem |
March 28, 2022, 19:32 |
Merouane Benderradji
Rep Power: 5 |
Hello everyone, I hope you are doing well
I am trying to do a CFD simulation on a centrifugal compressor stage. I have successfully defined the compressor rotor using BladeGen but I have issues with the geometry creation of the radial diffuser. the radial diffuser is consisted of 23 straight edged blades just like the one in the picture below, I did the drawing in solidworks and retrieved the meanline cartesian equation then I have calculated the theta angle distribution and bundled everything in a rtzt file. after loading it to BladeGen I get a different output then anticipated with curved fluctuations in the edge, the angle distribution is in one of the attached pictures. I hope someone can help me through this I am working on the radiver 2 centrifugal compressor and I have been stuck here for weeks. |
bladegen, radial diffuser |
[ICEM] Building geometry meshing problem | Yatharth Vaishnani | ANSYS Meshing & Geometry | 1 | June 12, 2016 07:33 |
[ANSYS Meshing] Problem in geometry meshing | Itachi11 | ANSYS Meshing & Geometry | 3 | March 15, 2016 15:38 |
heat generation problem | montazar | FLUENT | 0 | March 11, 2016 14:28 |
[ANSYS Meshing] Problem with meshing a complex Geometry (Hex) | fluent_beiyo | ANSYS Meshing & Geometry | 8 | April 26, 2014 05:55 |
[DesignModeler] problem with import geometry from catia | pavilion | ANSYS Meshing & Geometry | 1 | November 23, 2012 11:45 |
