[ANSYS Meshing] Mixing tank hexahedral mesh (with zero thickness rushton blade)
Old   March 2, 2022, 10:04
Default Mixing tank hexahedral mesh (with zero thickness rushton blade)
Bil
Bill
Bil is on a distinguished road
Hi everyone,
I am working on a stirred tank model with two rushton blade impellers and four baffles. I created a tetrahedral mesh, following the steps from this post Baffle (zero thickness) wall.
I would like to create a full hexahedral mesh in order to facilitate convergence and compare the results with the tetrahedral mesh. The end result should be similar to the mesh found in e.g. (Haringa et al., 2017). The steps I followed are:
1) Cut the geometry according to MRF model - Meshing and Interface set-up
2) Apply the sweep method to each of the new volumes.
The problem I encounter is that the Meshing tool doesn't apply the Sweep Method, due to the zero thickness blades and baffles (Sweep Method Active: No, Solid Contains Non-Manifold Face).
If I set the "Share Topology" of the components that include the blades and baffles to "Group" a full hex mesh is generated, but Fluent does not recognize the blades and baffles, i.e. I cannot set boundary conditions.
My question is: I there a way to create hexahedral mesh in a mixing tank geometry with 2D internals in the ANSYS Meshing tool or this task can only be done in ICEM CFD? Any tip is greatly appreciated!
For reference I attach screenshots of the two meshes for a simple geometry with one 2D baffle. The geometry was created in SpaceClaim.
Best,
Bill
Bil is offline   Reply With Quote
[snappyHexMesh] High quality mesh for wind in complex urban environment ziboaa OpenFOAM Meshing & Mesh Conversion 1 January 12, 2021 16:33
Mixing Tank 3D MRF case monty86 FLUENT 1 October 9, 2015 04:43
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
Reference value setting for mixing tank driven by rushton turbine Eakarach FLUENT 0 September 11, 2014 17:08
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
