[ANSYS Meshing] How to give different inflation layer properties for different regions of a domain. |
March 2, 2022, 03:24 |
Murali Krishnamraju
Rep Power: 4 |
I am trying to simulate a 3D flow filed around a cylinder using Large Eddy Simulation. My flow domain is given below, where the cylinder and bottom surface are specified as no slip boundary conditions.
As you can see from the figure, a finer mesh is used around the cylinder. Since I am using a no slip boundary condition on the bottom surface, I am giving an inflation layer on the bottom surface. But i am getting same inflation layers in both finer and coarser mesh regions. But, as the mesh size varies in the domain, I need to specify different inflation conditions at at finer mesh region and coarser mesh region. How can I do that ? Please help me with this. |
ansys meshing, boundary layer, inflation latyers, meshing 3d |
[mesh manipulation] createpatch not working when using layer addition in snappyHexMesh | Dikkeunit | OpenFOAM Meshing & Mesh Conversion | 0 | February 3, 2020 09:46 |
Inflation/Prism layer for rough surface | Dhairya@CFD | ANSYS | 0 | February 23, 2017 00:00 |
Pressure distribution on a wall | darazsbence | CFX | 17 | October 6, 2015 10:38 |
Prismatic boundary layer | KateEisenhower | enGrid | 5 | September 15, 2015 07:48 |
[snappyHexMesh] Boundary layer generation problems | ivan_cozza | OpenFOAM Meshing & Mesh Conversion | 0 | October 6, 2010 13:47 |
