February 7, 2022, 15:48 |
Polyhedral mesh gives bad results
Mohammad Shafiee
Rep Power: 7 |
I've been trying to simulate the air flow around and more importantly above an array of 5*5 cubic buildings. At first I generated a structured hex mesh using Gambit (since im much more familiar with it) but at some locations it did not give me acceptable results. I asked for a solution on the official Ansys forum and they told me that the error is due to the jump in cell dimensions in my original mesh and suggested to use polyhedral mesh. H9ZZE0XCA108.jpgROSIOLUT6ZTY.jpg So I went ahead and used ICEM to mesh my geometry using Delaunay tetrahedral scheme. Then smoothed it to be within the acceptable quality range and finally converted it to polyhedral mesh inside the Ansys Fluent. But now after the simulation, I'm getting a rough and weird velocity contour on the x-z plane: ADLAAI4BB7D0.jpgS6TBMK3EMTXL.jpg I suspect that this is most likely a mesh problem, but since I'm pretty new to ICEM and poly mesh, I don't know how to fix it. Any suggestions??? |
February 24, 2022, 13:39 |
#2 | |
Void_CFD-user
Rep Power: 4 |
has your solution converged, doesn't look very converged to me? Secondly, for your original hex mesh, you could have always reduced the growth rate of the mesh to get a better result, for your 2D case there is no reason why poly would be better than hex. I don't see a boundary layer in the poly mesh, is it there? |
February 26, 2022, 06:47 |
#3 | |
Mohammad Shafiee
Rep Power: 7 |
yes it is converged and both of them are 3d problems. I did generate a prism layer near the walls in the poly mesh. I also figured the problem with the poly mesh. I'm using a custom velocity profile at the inlet and my mesh wasnt able to capture the velocity gradient properly normal to the shown contour plane, so I had to refine it. thanks for your answer. |
April 3, 2022, 19:10 |
Kira
Rep Power: 9 |
I think you should look into the concept of Y+ in order to help guide your mesh refinement.
icem 17, polyhedral mesh, velocity contours |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
Polyhedral mesh has many more celle than standard mesh | klausb | enGrid | 2 | March 16, 2015 09:01 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 15:09 |
