[ANSYS Meshing] meshing for flow over complex bodies |
January 12, 2022, 11:13 |
mody
Rep Power: 5 |
hello, I have a complex body which I want to see the pressure drop over it.
when I try to mesh fluid with tetrahedral. My max skewness is .81 without inflation. can I come up with good results without inflation? which viscous model would I use then ? Then when I used inflation it went up to 94.5 Is it acceptable for max skewness? which viscous model should I use then? Capture.JPG |
boundary layer, mesh, mesh 3d, viscous model, y plus |
Computational Domain and Meshing for Complex Geometry | ashf9 | Main CFD Forum | 5 | February 26, 2021 11:01 |
[blockMesh] Problem with meshing complex geometry | Kelda | OpenFOAM Meshing & Mesh Conversion | 4 | April 16, 2020 09:21 |
[ANSYS Meshing] Complex aircraft meshing | lcbarreto | ANSYS Meshing & Geometry | 7 | January 4, 2018 09:03 |
[ANSYS Meshing] sweepable bodies & meshing | sandy_1982 | ANSYS Meshing & Geometry | 6 | November 1, 2012 08:04 |
Shared surface between bodies for better meshing? | alxe | ANSYS Meshing & Geometry | 5 | August 18, 2011 11:52 |
