[ANSYS Meshing] How do I open a mesh made in Ansys Fluent 2020 R2 on Ansys Fluent 2019 R3?
Old   November 2, 2021, 19:05
Default How do I open a mesh made in Ansys Fluent 2020 R2 on Ansys Fluent 2019 R3?
CA
Ryan T is on a distinguished road
How do I open a mesh that was made in Ansys Fluent 2020 R2 on an older version of Ansys Fluent? Specifically Ansys Fluent 2019 R3. I'm trying to open someone's Ansys Fluent file but it won't let me open it because I'm on an older version of Ansys.
Is there any way to just open the mesh in the older version of Ansys without having to upgrade?
Ryan T is offline   Reply With Quote
Old   November 3, 2021, 07:57
siw
Stuart
siw will become famous soon enough
If I recall correctly you cannot open a newer file in an older version of ANSYS. You can open an old file in a newer version of ANSYS.
siw is offline   Reply With Quote
Old   November 3, 2021, 13:29
Erik
evcelica is on a distinguished road
That is my experience as well. I believe it is one of ANSYS's ways of getting you to pay annual maintenance and use the current version, by making collaboration difficult.
I don't know of a workaround for mesh files. But I have been able to get some material files to work by modifying the file with a text editor (notepad) and replacing the newer version numbers with the version number I'm using. May not work for meshes though, material files are much simpler.
Good luck.
evcelica is offline   Reply With Quote
Old   November 3, 2021, 16:44
Gert-Jan
Gert-Jan will become famous soon enough
I have seen ICEM to be more forgiven with respect to version issues. So you can try to import the .msh-file in ICEM and then export it as fluent again. However, succes not guaranteed.
Gert-Jan is offline   Reply With Quote
[OpenFOAM.com] swak4foam compiling issues on a cluster saj216 OpenFOAM Installation 5 January 17, 2023 17:05
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 04:30
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
Ansys SIG$ILL error loth ANSYS 3 December 24, 2015 06:31
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
