[ANSYS Meshing] Meshing a loop
Old   October 23, 2021, 14:47
Default Meshing a loop
Dinu is on a distinguished road
I have a project where I have to mesh room with the inlet and outlet connected with a loop outside the room geometry. Does anyone have any suggestions where you use only one material point?
Thank you!
Dinu is offline   Reply With Quote
Old   October 25, 2021, 15:33
Erik
evcelica is on a distinguished road
Without full understanding what you need, I can provide a simple suggestion:
1. Simply set your inlet conditions based on your outlet conditions. Temperature and other scalar values can use massFlowAve(scalar)@Outlet when defining the inlet conditions. You can modify the inlet conditions as required if that flow is heated or mixed with other flows before returning to the inlet.
evcelica is offline   Reply With Quote
Old   October 25, 2021, 15:55
Thank you for your reply!
I have attached a picture of the model. I want to mesh the entire geometry but with one domain. Although i have done it with interfaces i'm not sure whether i can put the inlet and outlet as the interfaces. And when i load the mesh ino CFX, it shows inlet shadow and outlet shadow in boundary conditions. I want to run a simulation with just one fluid
Old   October 28, 2021, 16:39
Erik
Either use interfaces, or combine the bodies into one multibody part in design modeler or other CAD interface.
Then it will mesh with conformal nodes at the interfaces.
Of course you could just combine the two bodies into one body as well in the CAD program.
Old   November 1, 2021, 07:50
Gert-Jan
Gert-Jan will become famous soon enough
What is in the loop?
Gert-Jan is offline   Reply With Quote
icem, loop meshing
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 12:04
Pressure distribution on a wall darazsbence CFX 17 October 6, 2015 11:38
meshing error:the follwing faces have more than 1 external loop stenber ANSYS 0 September 30, 2015 10:06
Best Meshing scheme for Cylinder Nutrex Main CFD Forum 4 July 29, 2008 12:03
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 12:08
