[ANSYS Meshing] Dynamic mesh motion deformation |
September 29, 2021, 15:22 |
Igor Graçano
Hi, I have some problems with the dynamic mesh and would like the help of colleagues.
I'm implementing in my model a movement of pistons via profile in 1/8 cylinder. The movement itself is correct, however I have some difficulties in moving the mesh. I still haven't been able to do a full cycle. I'm using the dynamic mesh settings shown in the figures. The problem that persists is mesh deformation at the corners of the cylinder. What can I do so that this problem is minimized and floating point errors do not occur |
September 29, 2021, 20:14 |
Bryan Castro
Hi Graçano, i'm with some simmilar problem. The edge of the curved part is giving the same deformation and giving negative volume. I honestly don't know how to help you, I hope the other members of the forum can help you. Post the solution to your problem, maybe it will help me too.
Dynamic mesh using profile | sanjeetlimbu | Fluent Multiphase | 3 | April 19, 2018 10:49 |
How to ensure good cells with dynamic mesh motion? | petr.f. | OpenFOAM Running, Solving & CFD | 1 | December 27, 2016 12:40 |
Dynamic mesh Problem: How can I set UDF to the motion of train? | Majid Zarif | Fluent UDF and Scheme Programming | 4 | January 27, 2015 03:44 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 07:21 |
dynamic mesh: Wall deformation leading to pressure wave in 2D flow channel | drifter77 | Fluent UDF and Scheme Programming | 0 | May 8, 2013 10:32 |
