[ICEM] Dealing with meshing wing-flap problem |
July 17, 2021, 22:21 |
NGUYEN Van Huy
Hi every body,
I'm trying to mesh a flow domain around a wing with 2 flaps. - I generated unstructured mesh in ANSYS Meshing but cells near sharp trailing edge were very bad - After that, I tried to generate structured mesh by ICEM CFD but it is very difficult to build appropriate blocks Could you guys give me an advice an idea to mesh this model I attached a picture and .igs file below thanks for reading my question. |
July 18, 2021, 22:56 |
Kira
Rep Power: 8 |
Could you post an image of your blocking?
ansys meshing problem, icem cfd 16.2 |
[ICEM] ICEM CFD volume meshing problem | PietW | ANSYS Meshing & Geometry | 5 | September 15, 2020 04:19 |
Problem with ANSYS Meshing | Prasenjit Sanyal | ANSYS Meshing & Geometry | 1 | September 25, 2016 18:44 |
[ANSYS Meshing] Problem with meshing a complex Geometry (Hex) | fluent_beiyo | ANSYS Meshing & Geometry | 8 | April 26, 2014 04:55 |
[ICEM] Meshing problem in Formula one | Far | ANSYS Meshing & Geometry | 113 | April 23, 2013 12:36 |
GAMBIT meshing problem | Gauthier Lambert | Main CFD Forum | 1 | August 3, 2000 09:22 |
