[ICEM] Making conformal mesh at interface for MRF simulation.
Old   May 20, 2021, 12:45
Default Making conformal mesh at interface for MRF simulation.
António Reis
afreis is on a distinguished road
Hi everyone,
I'm currently doing my master's thesis on aerospace engineering and I currently need to simulate a rotating propeller near ground-effect. The problem is pretty much explained in the title, I've been trying different ways to make the unstructured mesh conformal at the interface between the background domain and the body domain to produce better results but I've been failing to do so. Until now what I have tried was:
-Making both meshes separately but then they are not conformal;
-Making both meshes together by uploading a geometry with the two bodies but, doing so, the input sizes at the part mesh setup are not respected;
-Opening the background geometry and importing the previously created body mesh in order to create the volume mesh from the surface mesh at the interface.
Sadly all my attempts have failed.
As a note, I'm using all tri for the surfaces with Delauny for the volume mesh.
In attachment I have the meshes I have generated.
Thanks in advance for your answers and I'm sorry if this is a simple topic but I'm just starting out with ICEM CFD.
Best regards,
AFReis
afreis is offline   Reply With Quote
Old   February 4, 2022, 11:14
Wales
DanMorris1 is on a distinguished road
Did you solve this issue?
DanMorris1 is offline   Reply With Quote
fluent, ground effect, icem, mrf, rotor
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 10:07
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
