[ANSYS Meshing] Conformal Sweep Mesh in Axial Direction with varying geometry |
May 17, 2021, 21:38 |
Rep Power: 5 |
I want a sweep mesh along the length of an assembly however I am getting errors at points where the geometry changes. All edges were shared in spaceclaim before hand and am unsure why ansys cannot figure out how to transition from one body to the next, when all it requires is tightening up the mesh at localized areas.
http://imgur.com/a/Ye0o8MN In the image, I want a conformal mesh with 3 elements thick across each body. |
June 8, 2021, 10:44 |
Rep Power: 17 |
It seems your model consists of many solids. You might have to sweep the simple or small ones first, and/or define hard edge divisions which are the same for each of the 3 sections.
ansys, conformal, fluent, mesh, sweep |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
[snappyHexMesh] snappyHexMesh - geometry does not appear in Mesh | czhongrong | OpenFOAM Meshing & Mesh Conversion | 1 | January 20, 2016 06:26 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 08:05 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 11:09 |
