[ANSYS Meshing] Modifies geometry while opening mesh window
Old   May 5, 2021, 08:20
Question Modifies geometry while opening mesh window
Satz's Avatar
Sathish
Satz is on a distinguished road
Greetings,
I have designed airfoil blades in solidworks and imported into Design Modeler. I noticed Trailing edge curve is not perfect and so I changed the facet value to the maximum. In design modeler the airfoil curve looks fine (first figure) with length 0.082326 m. But after opening the meshing window, the same airfoil curve at Trailing edge gets modified(blue dashed line) somehow as shown in the second figure. The length also got changed to 0.082324 m. Due to this I am unable to apply edge sizing and inflation properly. Please suggest me a solution.
In design Modeler
In fluent meshing
Thank you.
Satz is offline   Reply With Quote
curved edge, fluent meshing, geometry change
[snappyHexMesh] High quality mesh for wind in complex urban environment ziboaa OpenFOAM Meshing & Mesh Conversion 1 January 12, 2021 16:33
[GAMBIT] the boundary type of a window opening in a house geometry aiad30 ANSYS Meshing & Geometry 0 February 21, 2020 16:37
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 11:09
