[ANSYS Meshing] Ansys mesh generates only surface mesh but not volume
Old   May 5, 2021, 04:27
Exclamation Ansys mesh generates only surface mesh but not volume
Aarib Irfan
Aarib is on a distinguished road
I am trying to mesh a 3D HEPA Filter geometry. The Ansys mesh only creates mesh on the surfaces but not in the interior of the body. The inside of the body has no mesh at all. Can someone tell me how to solve this problem? Thank you.
Picture is also attached.
https://drive.google.com/file/d/1MtY...ew?usp=sharing
[IMG][/IMG]
Aarib is offline   Reply With Quote
Old   May 11, 2021, 08:22
kjetil is on a distinguished road
Do you have an interior "body" as a solid also? Does this get a check mark when you mesh the entire geometry, to indicate that mesh is finished?
kjetil is offline   Reply With Quote
Old   May 11, 2021, 09:08
Aarib Irfan
I get the green check mark after mesh is completed but there is no solid body inside it.
Old   May 11, 2021, 09:12
Then I guess you must create it prior to meshing?
Old   May 11, 2021, 10:17
Aarib Irfan
But i want air to flow inside the body from the empty parts. She is a complicated body so i can't create a solid body inside.
Old   May 11, 2021, 10:31
Are you combining solid, porous and fluid domains? In that case you need "solids" for all of them, and they're then defined differently in CFX/Fluent after meshing.
Old   May 11, 2021, 10:36
Aarib Irfan
So i can't make the air flow inside if i don't have a solid body inside?
Old   May 11, 2021, 10:38
Air will flow in their own "fluid domains". Nothing at all will happen in empty spaces. This is very different from when looking at a geometry in a 3D modelling software.
Old   May 11, 2021, 10:45
Aarib Irfan
Then is there a way to fill the geometry? It's a complicated Geiger and it can't be filled with simple fill command in design modeler
Old   May 11, 2021, 10:57
This depends on the software. "Volume extract" is one common term. Another way is to use a boolean to subtract a dummy volume from the physical object. Keep in mind that channels and gaps also have to be included, if appropriate.
ansys, filter, mesh
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 05:37
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 04:21
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 08:05
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
