[DesignModeler] Boolean Subtract produces improper feature, defeatures it |
Sathish
Rep Power: 5 ![]() |
Greetings,
I am working on Vertical Axis Wind turbine. I have designed turbine blade(planar surface geometry) in Solidworks and imported it into DesignModeler. Later I created a circular domain around it (made it into surface) and used Boolean operation subtract. But the outcome of the Boolean operation is not proper. I am not able to get the desired surface as the geometry gets distorted during boolean. Airfoil curve is not the same after Boolean subtract. How to do boolean subtract without loss of geometry feature? Capture.JPG With preserve tool body enabled Capture2.JPG Airfoil surface is not proper after boolean Thank You. Last edited by Satz; May 3, 2021 at 14:44. Reason: attach more image |
Erik
Rep Power: 23 ![]() |
That could just be graphical.
What does it look like after meshing? |
Sathish
@evcelica Thank you and I have fixed it by changing the facet value.
But I am facing problem during meshing process. In design modeler the airfoil curve looks fine (first figure) with length 0.082326 m. But after opening the meshing window, the same airfoil curve gets modified(blue dashed line) somehow as shown in the second figure. The length also got changed to 0.082324 m. Due to this I am unable to apply edge sizing and inflation properly. Please suggest me a solution. Capture14.PNG In design Modeler Capture15.PNG In fluent meshing |
Erik
Perhaps a smaller mesh size in that region?
The mesher is going to defeature the geometry according to the mesh size. Sorry, I'm not an expert at this stuff. |
boolean, boolean subtract, design modeler, surface |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
[DesignModeler] Problem with Boolean Subtract | collie | ANSYS Meshing & Geometry | 0 | December 10, 2018 05:42 |
Error with boolean subtract in Design Modeler | mattK | FLUENT | 6 | March 12, 2018 10:23 |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 14:07 |
Info message -> Fluent does not start | Jenson | FLUENT | 0 | December 22, 2011 17:21 |
