May 1, 2021, 11:34 |
Surface ID in ICEM CFD
RAJDEEP JAGDALE
Rep Power: 8 |
Hi everyone,
i am having doubt in ICEM CFD Meshing. While meshing the geometry, i noticed following messages over console like "possible error(3) in trim curves for surface F_4309(id = 5659)" and "no loop has positive area". From such messages, i suspect that, the surface F_4309 doesn't has bounding curves. So, my doubts are 1. how can i find this surface in my tin file, I have already named all surfaces, curves, points using create part option in ICEM CFD. 2. What the message "no loop has positive are" means and how to mitigate it? I also think that, these issue will take more time during meshing. So, any leads/solutions would be highly appreciated. Thanks in advance. Regards, RAJDEEP |
May 1, 2021, 12:25 |
Kira
Rep Power: 9 |
Hello Rajdeep,
Which program did you import your geometry from? |
May 2, 2021, 04:05 |
RAJDEEP JAGDALE
Rep Power: 8 |
If i understood your question correct, then I have converted the obtained parasolid fie (.x_t) to tin file for meshing purpose.
Surface ID in ICEM CFD | RAJDEEP | Mesh Generation & Pre-Processing | 0 | May 1, 2021 11:32 |
ICEM CFD Swept surface does not follow curves | MDN | ANSYS | 3 | December 6, 2020 07:27 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 16:03 |
Using ICEM CFD to repair/edit ANSYS Meshing | Kaaji1359 | ANSYS | 2 | July 30, 2013 11:28 |
ICEM CFD 5.0 (Hexa) - Internal Wall/Thin Surface | James Date | CFX | 3 | August 10, 2012 05:47 |
