April 12, 2021, 23:17 |
High Skewness Problem
Oliver Wijaya
Rep Power: 5 |
Hi ! I am doing a simulation of a free convection of aligned battery cell. I have some trouble when I am generating the mesh. When I check the mesh quality (T Grid Skewness), It appeared some of the mesh are still on the unacceptable range (the orange part in the picture below). Did anyone ever encounter this problem ? I really need help for this one to complete my undergraduate thesis. Thank You !
April 13, 2021, 00:44 |
Kira
Rep Power: 8 |
Hello Oliver,
You used O-Grids for each cylinder, correct? Also, I do not understand the 5th image you posted (the one where the mesh is green). Why is the mesh more fine in the top left corner, what view is that and why is it different? |
April 13, 2021, 01:47 |
#3 | |
Oliver Wijaya
Rep Power: 5 |
Yes, I used o-grid for each of the cylinder and about the 5th picture, I also didn't understand why it became like that (it shows that in the display for a few seconds when I start the ICEM, then it comes back to the normal display. even though I already set the mesh parameters in each o-grid, it still displayed the same problem |
April 13, 2021, 10:19 |
#4 | |
Kira
Rep Power: 8 |
I have seen element quality improve with O-Grids by putting another O-Grid inside. Might be worth a try, it's not too difficult to implement and test (make sure to save as a separate file, just in case). |
April 14, 2021, 00:22 |
#5 | |
Oliver Wijaya
Rep Power: 5 |
April 14, 2021, 00:30 |
Kira
Rep Power: 8 |
cylinder free convection, cylinder mesh, cylinder structured mesh, icem 3d, mesh 3d |
Problem in CHT simulation with high heat capacity fluid | Fole | FLUENT | 1 | September 26, 2017 08:42 |
[ANSYS Meshing] Problem with High Skewness Mesh | CFD2016 | ANSYS Meshing & Geometry | 12 | June 8, 2016 01:28 |
[ICEM] High Skewness | m5edr | ANSYS Meshing & Geometry | 5 | June 28, 2013 03:01 |
3D skewness problem | Santos-Dumont | FLUENT | 9 | August 8, 2011 03:42 |
TGrid High Skewness | khimkhim | ANSYS Meshing & Geometry | 1 | February 17, 2010 23:36 |
