[ANSYS Meshing] The mesh does not contain any shell elements
Old   April 5, 2021, 13:05
Default The mesh does not contain any shell elements
Na Be
NaBe is on a distinguished road
I'm working in ACP pre, I did the mesh generation and this message appeared : '' The mesh does not contain any shell elements. This may be because the model is not compatible with section data providers''
even though the green checked mark appeared next to model (workbench) and also as I update dthe project on workbench a message showed saying "ACP input validation failure. There is no data contained in the input mesh file'' please help me.
Thank you.
NaBe is offline   Reply With Quote
acp (pre), ansys19, mesh, mesh file, shell mesh
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" GuiMagyar OpenFOAM Meshing & Mesh Conversion 3 August 4, 2023 13:38
Bad elements after generating unstructured volume mesh max_beetle Pointwise & Gridgen 0 October 24, 2017 02:52
[ICEM] Nuclear fuel assembly, Mesh Check: "missing internal faces, uncovered faces" swparth ANSYS Meshing & Geometry 2 June 27, 2017 08:12
Gambit problems Althea FLUENT 22 January 4, 2017 04:19
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
