March 20, 2021, 06:32 |
ICEM Air foil hexa meshing
Ash
Rep Power: 5 |
I'm a complete beginner to ICEM and I've been following this tutorial to Hexa mesh an airfoil.
The tutorial: https://www.youtube.com/watch?v=NVyvEH-u0wQ&t=555s What I get and He gets after pre-meshing is completely different. Could anyone help me with where I had possibly gone wrong? Also at 10:45 on the video, he creates a new surface named Leading edge and he is able to choose the small part of the airfoil curve but when I select I'm able to choose only the entire curve. Someone, please help me with the issue. It would be great if you could replicate it and help me out. |
March 20, 2021, 13:44 |
Kira
Rep Power: 8 |
You need to delete the blocking inside of the airfoil, then re-mesh. To make a leading edge, add some points along that curve (either by location or give it a parameter where you want the points to appear), then use the segment curve, then select the curve and the points where you want to split it. |
March 23, 2021, 03:18 |
Ash
Rep Power: 5 |
Thank you. It works now
cfd, hexa, hexamesh, icem, mesh |
[ICEM] Is there any way to keep previous meshing in ICEM when I back to the ICEM from wbrenc | Togtokhbuyan Munkhunur | ANSYS Meshing & Geometry | 0 | May 6, 2020 09:33 |
[ICEM] ICEM Hexa meshing tutorial - Wing with sharp trailing edge | Far | ANSYS Meshing & Geometry | 34 | October 21, 2013 05:46 |
[ICEM] Meshing problem with ICEM | aylalisa | ANSYS Meshing & Geometry | 21 | January 22, 2013 17:22 |
[ICEM] ICEM Hexa Meshing Automation | Haasini | ANSYS Meshing & Geometry | 1 | April 24, 2012 22:46 |
Hexa + Tetra meshing (Hybrid) in ICEM | vmlxb6 | ANSYS Meshing & Geometry | 12 | December 27, 2010 10:18 |
