[ICEM] Interfaces between different 3 domains
Old   March 11, 2021, 03:46
Unhappy Interfaces between different 3 domains
Larissa C.Pinheiro
Shanaylla is on a distinguished road
Hi all,
I have been struggling some days now with an ICEM interface problem, ANY help would be much appreciated.
I attached some self-explaining images of the geometry and the mesh. These images and questions are related to a reduced model of my real problem (three annular tubes inside a fluid domain).
In the underlying model, I have 3 domains: two fluid domains and a solid domain (the tube). The external domain is fluid which encompasses an annular tube with some wall thickness. Fluid is also flowing through (inside) the tube.
When a mesh the external fluid, the face against the tube should be an interface between it and both the tube and the inner fluid. However, while I have just one interface at the external fluid domain I got 2 faces touching it: one from the tube and another from the inner fluid.
When I open this mesh in CFX-Pre it eighter tells me that I can only use one face from each domain to create a domain interface or put this face as a "default wall" (in case I don't assign a boundary condition to it).
Any help would be much appreciated since I have tried many unsuccessful tricks.
Shanaylla is offline   Reply With Quote
Old   March 15, 2021, 16:06
Larissa C.Pinheiro
My problem is actually that I have interfaces with different sizes. Anyone has ever faced such a problem?
ansys, cfx-pre, icem, interface defining
[ANSYS Meshing] Displaying solid domains in CFD Post without meshing them. hda ANSYS Meshing & Geometry 5 October 24, 2016 10:26
Discontinuity across interfaces Nurzhan CFX 2 March 11, 2015 02:59
Frozen Rotor 1:1 Mesh Connection pharley CFX 5 January 31, 2013 17:15
[ICEM] Using a ICEM mesh with multiple Domains in CFX without Domain Interfaces ChristianF ANSYS Meshing & Geometry 0 January 24, 2012 06:51
Multiple Solid Domains - Interfaces Scott CFX 8 July 31, 2008 16:20
