[ICEM] Mesh above curved surface causing problems
Old   January 3, 2021, 13:09
Question Mesh above curved surface causing problems
Athena
illuminated is on a distinguished road
Hello! I am struggling with improving the mesh above the pipe as shown in this diagram. What can I do to fix it? The pipe's curved surface in this diagram is in contact with the absorber plate and it is a rectangular surface.
What changes can I make for improvement?
The pipe is surrounded by PCM, and in this diagram, the mesh is all curved in the PCM area as well. Is it alright to leave it like that or should I do some improvement?
illuminated is offline   Reply With Quote
Old   January 3, 2021, 15:30
Kira
aero_head is on a distinguished road
How did you block the internal cylinder, have you used an O-Grid? O-Grids can drastically improve element quality around circular objects.
It would help to add an image of your blocking.
aero_head is offline   Reply With Quote
icem cfd, icem mesh, icemcfd, meshing, meshing advice
Gambit problems Althea FLUENT 22 January 4, 2017 04:19
[ANSYS Meshing] First layter thickness on mesh causing problems Rik102 ANSYS Meshing & Geometry 0 November 4, 2016 10:51
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
[ICEM] How to generate sunstructured "all-tri patch-dependant" surface mesh in ICEM? jash ANSYS Meshing & Geometry 19 July 23, 2013 19:48
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
