Athena
Rep Power: 5 ![]() |
Hello everyone! I am completely new to ICEM CFD and ANSYS in general and this has been the most confusing task for me to accomplish. I managed to get a pre-mesh for my PV/T-PCM collector, however, there are some problematic areas within the mesh that I need to correct to improve quality.
I have no idea what needs to be done to fix these edges. Could anyone please guide me on this? I would really appreciate it. Below I have attached an image of the collector, an image of the problem area, and lastly a close-up of how the mesh looks like in the problem area. 1.jpg 2.jpg 3.jpg If possible, please explain in a simple way since I really depended on youtube tutorials for the majority of this task and still don't have a good grasp on how this software works. ![]() |
Kira
Rep Power: 8 ![]() |
Hello Athena,
How did you mesh around the cylinder, did you use an O-Grid? It might help to include a photo of your blocking. |
#3 | |
Athena
https://www.youtube.com/watch?v=SuuB...tmikoErlambang Also, the blocking pictures are attached here. 6.jpg 7.jpg I tried increasing the number of elements in the meshing but that didn't seem to make a difference with this problem either. ![]() |
Kira
Hello Athena,
That is an interesting blocking strategy. I myself have followed the following tutorial; it uses a different blocking strategy, one that I had no problems with negative volume elements for: (for 3D): https://www.youtube.com/watch?v=l-Tz6MHlT1M And this is a similar one for 2D: https://www.youtube.com/watch?v=T2Dxa0OZf58 Also, looking at the first set of pictures in your original post... The third picture of the problem area with the yellow box around it looks like an association is off (i.e. it looks green where it should be purple). Is the surface there correctly associated with the purple (looks like PCM_INLET)? It appears to be associated with the PCM_BOTTOM_WALL. However, in any case, ICEM really doesn't do well with sharp corners as in those elements, so it is not surprising you have issues there. It should look more like what you have done for the bottom of the cylinder. Last edited by aero_head; January 3, 2021 at 23:24. Reason: Edited for clarity |
#5 | |
Athena
But thank you so much for your response! |
#6 | |
Athena
Also, the video that you sent is basically a cylinder going through a wall, but mine's a pipe, so theres another layer for the circular external walls. Not just a hole. Will I have to do something different for it during the blocking? |
Kira
Ah, I understand what that section is for now. Yes, ICEM, and I am sure ANSYS Meshing, would have problems with that green section. Check the skew (Angle) in ICEM of those elements. I am sure it is under the minimum acceptable skew angle of 18 deg. in those sections. Sorry, yes, there will be a small difference between the video and your geometry, as your pipe has a thickness. It was just to illustrate a different blocking strategy you could use to lower the skew angle in that area. You would likely need to do a double O-Grid with the interior block. Last edited by aero_head; January 4, 2021 at 23:29. Reason: Added more info |
icem cfd, icem cfd meshing, improve mesh quality, mesh quality |
Mesh Quality - ICEM CFD | aamirasees1995 | ANSYS | 1 | February 21, 2019 02:39 |
[ICEM] Imporving Hexa mesh quality in ICEM CFD | Far | ANSYS Meshing & Geometry | 0 | February 3, 2018 06:45 |
Import Mesh from ICEM CFD to CFX | Andre Almeida | CFX | 16 | April 19, 2016 03:42 |
[ICEM] Improving mesh orthogonality in ICEM or Fluent | Harshal | ANSYS Meshing & Geometry | 0 | December 2, 2013 09:04 |
----------------2D mesh with ICEM CFD | Abir | FLUENT | 2 | September 12, 2008 23:55 |
