December 24, 2020, 04:30 |
Prism height limit factor
harshavardhanps
Rep Power: 5 |
Can anyone explain to me about the prism height limit factor? Where to use it? I went through the manual but I did not understand that. your help is means a lot.
December 24, 2020, 16:02 |
Kira
Rep Power: 9 |
This thread might answer your question(s) on this topic: [ICEM] Auto prism layer growth to unity In sum, prism height limit factor stops layer growth once a specified height over base is reached. i.e. a prism height limit factor of 1 means that the prism ratio will be reset to 1 when the layer height becomes equal to the average base side length. However, it still continues to add layers of uniform thickness after that... If this is meant to smooth transition to the volume tetras, remember that a tetra with base 1 has a lot less volume than a prism with base 1 and height 1. |
[ICEM] How to get prism layer with varying first cell height | harshavardhanps3839 | ANSYS Meshing & Geometry | 3 | December 22, 2020 07:05 |
[ICEM] How to improve bad quality elements that are obtained after creating prism layers? | Rohith Giridhar | ANSYS Meshing & Geometry | 2 | July 11, 2015 19:04 |
[ICEM] Prism layers distorted near trailing edge of blade-Unstructured Mesh | Rohith Giridhar | ANSYS Meshing & Geometry | 3 | June 29, 2015 18:52 |
Prism layers and grid dependence study | jcamilleri | STAR-CCM+ | 4 | July 7, 2014 14:47 |
Getting prism to inflate into mixed tet-hex meshes | Joe | CFX | 16 | October 10, 2011 08:06 |
