[ICEM] How to get prism layer with varying first cell height
Old   December 21, 2020, 13:16
Default How to get prism layer with varying first cell height
harshavardhanps
harshavardhanps3839 is on a distinguished road
I am doing my mesh in ICEM. I am looking for tetra mesh in contraction and test section of a wind tunnel problem I am facing is the first cell height in contraction and test section are different then, how to get prism layers that varying first cell height?
harshavardhanps3839 is offline   Reply With Quote
Old   December 21, 2020, 15:19
Sebastian Engel
bluebase will become famous soon enough
In the part mesh setup,
there is a checkbox to use inflation parameters for curves you need to set for 2d meshing. Then set fill the respective columns. The height column is the first layer height, afaik.
bluebase is offline   Reply With Quote
Old   December 22, 2020, 01:49
harshavardhanps
Thanks for your reply but geometry is 3-D.
Old   December 22, 2020, 07:05
Sebastian Engel
Well... there are three Tetra/Prism tutorials in ICEM's tutorial manual. Did you get a chance to look at them? They walk you through three different approaches how to setup prism layers.
Best,
Sebastian
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 12:04
[ANSYS Meshing] Consideration of first cell height of prism layer for laminar flow in heat transfer p swapnil13 ANSYS Meshing & Geometry 0 September 8, 2019 04:42
Prism cell near wall layer ASPECT RATIO vivekch Main CFD Forum 0 December 24, 2014 06:17
Trimmer & prism layer peresah STAR-CCM+ 6 October 6, 2009 15:39
errors Fahad Main CFD Forum 0 March 23, 2004 14:20
