[ANSYS Meshing] [CFD Fluent] Match control and inflation layer |
December 3, 2020, 13:03 |
Rep Power: 6 |
Hi everyone,
for my master's thesis I'm simulating the flow around blades of a steam turbine. I want to generate an unstructured mesh with an inflation layer at the walls (for k-omega SST model). Addytionally at the top and at the bottom boundary I need periodic boundary conditions. Hence I need the match control. Out of any reason match control and an inflation layer is not possible at the same time. For the geometry I'm working with Design Modeler. Attached you can find a picture of the simulation domain. Left boundary = Inlet, Right Boundary = Outlet Does anyone know how it is possible to fix this problem? Thanks a lot! |
December 11, 2020, 09:26 |
Lorenzo Galieti
Rep Power: 12 |
Can you show me your mesh settings? Pictures |
December 14, 2020, 05:22 |
Rep Power: 6 |
Is this enough? Or what do you want to see exactly?
ansys meshing, inflation layer, match control |
[ANSYS Meshing] 2D inflation layer contains triangles | jones007 | ANSYS Meshing & Geometry | 8 | May 4, 2020 09:42 |
[ANSYS Meshing] First Aspect Ratio Inflation control missing in ANSYS Meshing? | spggodd | ANSYS Meshing & Geometry | 4 | February 23, 2016 23:16 |
[ANSYS Meshing] Inflation vs. pinch control | Edee | ANSYS Meshing & Geometry | 1 | October 14, 2015 11:22 |
[ANSYS Meshing] Inflation layer | federico.bruni | ANSYS Meshing & Geometry | 2 | October 29, 2012 09:25 |
[ICEM] Complex 3D geometry Hexa blocking and inflation layer | Chipsgrottel | ANSYS Meshing & Geometry | 4 | September 30, 2011 04:25 |
